996 Forum 1999-2005
Grille missing from filter box?
Old 04-17-2018 | 04:15 AM
ViciousViper's Avatar
ViciousViper
Default Grille missing from filter box?
When I was replacing the air filter in my 996, I noticed that there was only a fine mesh on the "filter side" of the MAF, but no plastic grille. I'm not sure if it's supposed to be a grille there in addition to the fine mesh, or if it's missing? I was unable to find any decent pictures showing the inside/MAF section of the filter box. Does anyone know? Thanks
Old 04-18-2018 | 12:14 AM
dan_189's Avatar
dan_189
Yes, there should be both a plastic screen and a fine mesh, the unfortunate news is the air box is only available as an entire unit to purchase.
Ebay pic, you can see the plastic mesh grill:
Old 04-18-2018 | 12:20 PM
ViciousViper
Thanks! As I suspected... In that case, Ebay will probably be my best bet.
Old 04-18-2018 | 02:45 PM
ViciousViper
Do you happen to know if there are any differences between a 3.4 and a 3.6 filter box? They look identical as far as I can tell.
Old 04-18-2018 | 07:29 PM
dan_189's Avatar
dan_189
Same airbox between the 3.4 and 3.6 there is only one change between them - how the snorkel part attaches to the box. Later boxes have 3 tabs earlier boxes have one. Also 3.6 boxes have some foam baffling.
No performance or operational difference
Old 04-19-2018 | 07:05 AM
ViciousViper
Thanks again, Dan. So, the upper lid may be exchangeable between a 3.4 and 3.6, then... The easiest is probably to get a complete box anyway😁
Old 04-19-2018 | 07:08 AM
dan_189's Avatar
dan_189
Yes correct, the tops are interchangeable.
I think you can buy just the top off US ebay.
Old 04-19-2018 | 07:12 AM
ViciousViper
"Exchangeable"... now, where the h... did that come from? I must be tired😜 Interchangeable! I'll give ebay US a shot, thanks☺
Old 04-19-2018 | 07:16 AM
dan_189's Avatar
dan_189
Would be great if you could exchange it! No problem, there is a top alone on AUS ebay but not too sure about the shipping.
Might be better off sourcing one locally, best of luck!
Old 04-19-2018 | 07:25 AM
ViciousViper
Yes, that would have been awesome☺ I found one in the US, but the shipping is almost twice the price of the item itself😐 I'll try to source one locally first... Thanks!
Old 04-19-2018 | 04:36 PM
ViciousViper
I managed to find one off Ebay for a reasonable price (including MAF!). Thanks again for your help, Dan. I'm considering this problem solved.
Quick Reply: Grille missing from filter box?
