996 Forum 1999-2005
ODB code P0011
Old 02-27-2018, 12:07 AM
az968gpw
az968gpw's Avatar
Default ODB code P0011
My car is reporting P0011. Changed the cam sensor and checked grounds. Oil is fresh. Any thoughts? Thanks.
Old 02-27-2018, 12:22 AM
Ahsai
Ahsai's Avatar
Check this thread?
https://rennlist.com/forums/996-foru...l#post13397579
Old 02-27-2018, 12:36 AM
az968gpw
az968gpw's Avatar
Thnaks, I didn't find that when searching. This will be a good start.
Old 03-10-2018, 11:25 PM
az968gpw
az968gpw's Avatar
So still getting this error code. Here's what's been done to identify cause.
Found left side off approx 10 degrees from expected value in the retard direction, right side is fine, by using durametric. Replaced left side cam tensioner adjustor solenoid with no change. Swapped cam position sensors, no change. Used two scan tools to cross-check with same results.
Using a tool from F6I (for replacing IMSB) manually checked physical alignment of both cams and it looks like the left bank cam is off by about 10 degrees. and the cam couldn't be rotated by hand.
Next recommendation is to remove the cam cover and see what is in there. That might entail dropping the engine, so expensive.
The engine was rebuilt 16k miles ago and it is hard to imagine that the shop would not have assembled the engine correctly with new parts.
Anyone have any thoughts?
Old 03-11-2018, 01:55 AM
Ahsai
Ahsai's Avatar
Is your engine a 5-chain? What does it mean by "the cam couldn't be rotated by hand."?
Old 03-11-2018, 10:13 AM
az968gpw
az968gpw's Avatar
I'm not sure about the chain, how would i be able to tell?, I'll have to research that, it's a 3.6 taken out to a 3.8.. By "cam couldn't be rotated" I mean there wasn't any slack in the chain that would allow the cam to be rotated with the hand tool, so pretty sure the chain hasn't stretched..
Old 04-06-2018, 08:26 PM
az968gpw
az968gpw's Avatar
So the diagnosis is coming back that the likely culprit is:"In this case it sounds like the intake vane cell adjuster may be sticking".It's definitely not the chain stretching, it's a motorsports grade timing chain, made by IWIS in these engines.
My local shop quoted me about 10 hrs labor and $450 for the part..That's about $2k worth of work. Anyone ever replace one of these, is the estimate in the ballpark?
Old 04-06-2018, 09:24 PM
Ahsai
Ahsai's Avatar
Yes, your's is a 3.6 so 3-chain variocam plus engine. To remove that intake cam vane adjuster requires removing the cam cover, cams, and then re-time the engine. The quote sounds reasonable to me.
Old 04-06-2018, 09:47 PM
rael
rael's Avatar
Is this the BAT car from a few months ago?
Old 04-07-2018, 12:19 AM
az968gpw
az968gpw's Avatar
Yes, and I've gotten great support from F6I on diagnostics from afar. But it looks like this part is sticking and will have to be replaced.
Old 04-07-2018, 12:33 AM
rael
rael's Avatar
Maybe give Scott a call at McIlvain in Tempe? He has a great labor rate and super easy to deal with and they do not nickel and dime you. They do a ton of 996 and 986 work and they are genuinely nice guys and explain everything really well.
No affiliation, just a happy client.
Old 04-07-2018, 01:01 AM
az968gpw
az968gpw's Avatar
Scotts an option. I'm going to check with Jack Doverspike on Monday for his rhoughts.
Old 05-01-2018, 08:20 PM
az968gpw
az968gpw's Avatar
So an update on my car. Just had an opportunity to have the camshaft actuator for Bank 1 replaced. That was the problem, apparently these fail (stick) every so often and it just happened to happen on my car. Nothing to do with the rebuild, just a Porsche part that failed (where have I heard that before). Here's what it looks like, the small pieces are the vanes that are internal, just removed for inspection. This part sits on the end of the camshaft with the chain on it and, as I understand, it is the device that makes the variocam vario, advancing the cam. There was internal wear that could only be seen by disassembling the part and one or more vanes was sticking, thus the cam couldn't advance or return.
No more CEL, and the engine runs like a beast!
Old 11-05-2018, 05:03 PM
GTA_G20
GTA_G20's Avatar
If you didn’t mind my asking how long did it end up taking and was it the same 10 hours and $450 part you mentioned above. My car has the same CEL
Old 11-05-2018, 07:25 PM
az968gpw
az968gpw's Avatar
Yep, it was billed at 10 hrs labor. The camshaft actuator was $490 and maybe another $100 for misc other parts (gaskets, freight,.etc.) Was repaired end of April and 4k miles later no problem. Sorry you are seeing the same thing. I had three quality sources advise it was the camshaft actuator, esp since the camshaft was 10 degrees retarded and was not changing. Not sure what other items cause this error. For sure if you have the engine opened up make sure they check to camshaft retard to make sure it was the same problem i had.
Quick Reply: ODB code P0011
