Decent all season tires for 18" wheels?
Yokohamas.....I don't use the car in snow nor track.....price is right and they are.very quiet right up to full wear....seems like every other tire I used would whine within a couple thousand miles of use
I have blizzaks on my car this winter. They are great in the cold, and decent in snow, but the car can still scare me in slush and half plowed and salted crap. Mine also has no PSM and is a C2
I run PIlot sport all season 3+ on the standard size 18s on a C2. I live in CT. I drive it as long as there isn’t snow on the road. I have also run them during a DE day. I don’t have much to compare them too but they are pretty solid.
Hold on a second right there, mister. I have the P/S A/S 3+ right now on my C2 & the rears are slightly out of spec (285/35 instead of 285/30 - slightly larger overall diameter). It's fine for me but if they make a 285/30 I'd like to know
. So, are you sure the rears are in spec? OP has a lowered suspension so he doesn't want to rub with the larger diameter 285/35 rears. If the 30s exist, his problem might be solved (mine too).
225/40 front and 265/35 in the rear.. so I must have those specs I imagine. I just looked at photos and the vehicle capacity/weight sticker with the tire diameter lists 225/40 ZR18 front 265/35 ZR18 rear so I don't know where 285/30 is coming from.... I haven't had any issues running those sizes and I think those are OEM spec...
I run dws06 on mine. I know on those, when racing on the back roads at 100mph I'm losing to you guys with the summer tires, but that's OK
Anyway. Weird thought. Just use summer tires all year and the truck for the snow.
you tube engineering explained winter vs summer tires
