Jim's and his wife's 996
#121
Once we pulled out all the aftermarket stuff and tapped everything up, it wasn't so bad. Just need to finish upholstering the new leather dash, replace a couple of pieces that broke (ugh - always seems to happen ...) and we can start to put it back together again.
#126
Well, this one was a pain. And there are TWO blend doors!! I can't get the other one without going in from the bonnet. That is the one everyone fixes. But this second one can only be accessed from the dash, like another member did.
#131
well, test fitted the new dash...
Looks like if anyone wants to switch the dash for one with a glovebox, you need a couple more parts then I first thought.
Need the following (I have it already):
bracket - 996.552.753.00
inner right air duct - 996.572.464.02
Just found out I need this too, sigh ...
outer air duct - 996.572.768.01
center air distributor duct - 996.572.171.04
central dash frame for 02-04
Going to have to order some parts off Ebay ... luckily not expensive. Just have to wait longer to put everything back together.
#133
Stripping the 'asphalt' Paint finish off the trim using brake fluid. An old modeler's trick to get paint off plastic without damaging the plastic.
#134
#135
Contact Alina at High End Motorsports
Motorsports <alina@high-end-motorsports.com>
I gave them the patterns to make the bonnet mat and the 2 shelf mats. They said they would make it available for everyone. We're even going to use my pictures, lol.
