RSS TOP SELLER | 901 Series 4pt. Harness Bar | 996-997 | In Stock!
RSS TOP SELLER - 901 Series 4pt. Harness Bar 996 - 997 - In Stock! - Bose Rear Sub Woofer Compatible
• Fits ALL 996 & 997 MK1 & MK2 Models Including GT3/RS and GT2
• 1.5" Steel Tubing, .095 Wall Thickness
• Bolts To Front/Rear Seatbelt Mounts
• Mig Welded, No Sleeved Tube Connections
• Flawless Fit To Interior Profile
• Retains Full Function of Most Front Seats
• Offers Harness Connection Points & Motorsport Looks
• Available in Standard Black (30), White (32), Red (34) or Raw (00) (unfinished - ready for paint match)
• Easy Bolt-In Installation – No Drilling Required
• Handmade on Location in Southern California, USA
• Will Fit Vehicles with Sunroof
• Please Enter Color Choice in Comments Section in Shopping Cart
WILL FIT Models with Bose Rear Sub Woofer.
Note: Rollbar Ships On A pallet, We Will Contact You with Final Shipping Quote Via UPS Freight.
RSS Website Direct Link: http://roadsportsupply.com/901-34-4p...es-finish-red/
If you want the mother of all bars...
Ask RSS Mike about their bar that attaches in the rear to the shock towers and to the chassis (Yes, you'll need to drill some holes) just aft of the B pillar. I am having the bar installed in the next few weeks. I'll post up some pics. The RSS bars are super high quality in my opinion....I did lots of research before selecting the RSS...I have a spread sheet posted on the 996 GT3 Board comparing the various brands available for there 997 and 997 chassis, coupes.
-Mike
901 Harness Bar (Bose Sub-woofer): http://rss.rpmware.com/rss/rss-901-s.../i-238428.aspx
930 Hybrid Bar: http://rss.rpmware.com/rss/rss-930-s.../i-402509.aspx
931 Competition Bar: http://rss.rpmware.com/rss/rss-931-s.../i-527135.aspx
How come the red bar pictured is missing one of the diagonal bars going from the lower left rear anchor point to the top right?
Also, is it possible to show a photograph taken from a reasonable driver's-eye position showing how this looks in the rear-view mirror, i.e. how much it hurts rear visibility?
Generally the rearward visibility is quote good in terms of the top horizontal tube and 2 diagonal bars. I will search for some pics...
The 901 Harness Bar shares the mounting points with the Old Porsche Techquipement Bar. Horizontal mounting points are at the reinforced seatbelt anchor points. It is designed as a 4pt. Harness Bar. You can see the mounting points in photo above. It offers a Harness Bar Mounting Solution with the Roll Bar looks/style while being minimally invasive in terms of cutting the carpet and performing permanent mods to the car. This is also an ideal option for vehicles equipped with the BOSE Subwoofer who want to run a Harness Bar with the Roll Bar Look, as it does not require the removal or modification of the BOSE.
The 930 Hybrid Bar in contrast, as the name implies, is a Hybrid of a Harness Bar and Bolt in Roll Bar. It mounts to the front seatbelt anchor point and the top of the rear shock towers. It requires carpet panel trimming a the rear mounts.
There are no certifications for either 901 or 930 as they are not TRUE Roll Bars. For that application, we have the 931 Bar (See below) which exceeds the stated specs for most sanctioning bodies that I am aware of. The 931 Mounts at the front unibody frame rails and rear shock towers. Ideally it should be welded in place to be a proper or True Roll Bar.
Just restocked on the 901 4pt. Harness Bars!
Check them out on our New RSS Webiste: http://roadsportsupply.com/search.php?search_query=901§ion=product
I have not confirmed that fitment personally, but would venture to guess the sliding glass panel my not provide enough clearance. If your local we could have a look or email me (see signature below) and we could provide you some measurements that may confirm fitment.
901 Harness Bars - BACK IN STOCK!
