What IMS cover is this?
it only has one mark, a K. Compared to another OEM one.
car is a 99 996 with 164k miles.
99 will be the dual row bearing if it’s standard, if it’s gone that far leave it alone, lock engine in TDC, pull the cam chain tensioners before you remove the ims flange, once flange is off, pop the bearing seal off carefully with a small pick, this will let better oil inside to help it go on longer!
99 will be the dual row bearing if it €™s standard, if it €™s gone that far leave it alone, lock engine in TDC, pull the cam chain tensioners before you remove the ims flange, once flange is off, pop the bearing seal off carefully with a small pick, this will let better oil inside to help it go on longer!
