996 Forum 1999-2005
Hard to start 2001 996
Old 10-24-2017 | 04:21 PM
mmeltz's Avatar
mmeltz
2nd Gear
Default Hard to start 2001 996
I need to really push the clutch pedal HARD against the floor to get the starter to engage. During operation, the clutch pedal is final, options?
Old 10-24-2017 | 04:25 PM
tcc's Avatar
tcc
You may need to get the clutch lockout switch replaced at the pedal. if that's what it is, it's a cheap fix.
Old 10-24-2017 | 04:37 PM
mmeltz's Avatar
mmeltz
2nd Gear
Default Thanks
I will give that a try, the part is like $35.00
Old 10-24-2017 | 04:52 PM
Ahsai's Avatar
Ahsai
You may also be able to adjust the switch a bit or the switch itself is loose.
Old 10-24-2017 | 11:03 PM
rockhouse66's Avatar
rockhouse66
My carpet mat slides forward while driving and prevents the clutch from traveling far enough to activate the switch. Short moment of panic every time. I decided to just eliminate the switch so I could make cold starts without depressing the clutch (and quit fiddling with the carpet mat).
Old 10-24-2017 | 11:24 PM
Montychristo128's Avatar
Montychristo128
Elimination seems like a good plan. Will help to extend thrust bearing life too. I'm assuming its just a case of wiring the ends together and bingo it works.
Old 10-25-2017 | 10:19 AM
rockhouse66
Yes. I went a little fancy and used one of those 2 into 1 spade connectors and just plugged into one of the switch terminals and then plugged the two switch connectors into it. I can reverse it any time in about a minute.
Old 10-25-2017 | 04:27 PM
Montychristo128
I was thinking about a small switch, would be great as a theft deterrent, assuming people still steal cars!!
Old 11-27-2017 | 04:59 PM
RazorKQ's Avatar
RazorKQ
I like this idea. I think I will do that with mine.
Quick Reply: Hard to start 2001 996
