996 Forum 1999-2005
Steering Oil
Old Nov 24, 2003 | 02:30 PM
Waz996's Avatar
Waz996
Question Steering Oil
I noticed the steering oil (the black dipstick on the right of the engine oil is steering oil, right?!) is not up to the level mark, neither in hot or cold temps..
The manual is in german and i cant understand what to do to level it up, should i add oil in hot or cold engine temp?
Moreover, it says Pentosin CF11S or smthg.. Is there any equivalent oil i can add to top it.. Regular power steering oil from a station wont do? Any spec i should look for?
Thanks,
Waz
996 99 C2
Old Nov 24, 2003 | 02:36 PM
Palting's Avatar
Palting
I check it when hot. The level was low on delivery, something that the pre-delivery inspection failed to note, and the service department gave me a whole can to sort of makeup for it. You should be able to get the can from Porsche dealer. Be careful when topping off. It takes very little to go from just barely at the tip of the dipstick to overfull.
Old Nov 24, 2003 | 02:55 PM
Waz996's Avatar
Waz996
i cant buy any oil from outside of the dealer for the purpose?
Old Nov 24, 2003 | 03:27 PM
Palting's Avatar
Palting
Don't know. I'll check on the can when I get home and give you the brand, grade, etc, and you can see if you can get the same thing elsewhere.
Old Nov 24, 2003 | 07:38 PM
Palting's Avatar
Palting
FWIW, here's what the can looks like.
Old Nov 24, 2003 | 08:00 PM
mastermind's Avatar
mastermind
I would not risk buggering up the power steering by using anything other than the Pentosin... it is a synthetic hydraullic oil and they obviously spec it for a reason - make sure you get the right Pentosin... I think they also make a CHF 7.1 or something that is not compatible with the CHF 11 !!!!!
You should be able to get this at any supply shop that deals with VW/Audi/BMW - it's spec'd in a lot of those cars as well..... I recall having to get some years ago for my 944 when putting in a new steering rack - I was told I was crazy if I used anything else....
trev
Old Nov 25, 2003 | 01:03 AM
Waz996's Avatar
Waz996
Ok guys.. thanks for the info.. Guess i'll get it from the dealer after all.
Wael
