High Performance 996 Headlights: Build Log
#62
Excellent!
#65
#69
As a headlight mod guy myself, very nicely done.
Personally, I have learned that these mods are for the most part a complete waste of money and time. The amount and effort you went through seems completely ridiculous to me only for a little more output which, as you know, could have been achieved without opening the headlights.
I've learned that I'd rather have sealed, non-foggy headlights, versus 'cool' modified versions. But I also hate black painted headlights and working on the chrome internals without fingerprints/scratches is flat out impossible.
I do love the Miromoto stuff though but I'm guessing you charged no less than $3000 for the headlights.....can't believe someone actually paid that. I've always wondered how clearcorners.net stayed in business...
#70
Value is relative, so what you value may not directly translate to the view of others believe it or not.
Foggy headlights can happen, it can happen to brand new oem headlights, it happens on a Koenigsegg. If modified headlights leak or not depends on the attention to detail and skills of the retrofitter and let me tell you, not all retrofitters are created equal.
I helped a fellow forum member build these lights so the build was tailored around his requests and an upgraded fog projector with a yellow light output was what he wanted. Is it what I personally would have done? No, I would have put the resources into upgrading the projector to the Lexus RX350 Bi-Xenon.
Morimoto is a dead average aftermarket lighting company, they are a huge global company which does an EXCELLENT job marketing (it worked on you) and designing "easy to retrofit" projectors for the masses who don't have the skills to execute a "proper" retrofit, their projector performance is usually sacrificed for keeping the footprint small and the projector easy to retrofit. The reliability of their HID components leave a lot to be desired, I prefer using oem components whenever possible.
#71
These are really nice lights imo. The 996 is regarded as a great platform to mod, so tasteful work like this can incrementally add character to different builds. At some point in the next few years, I'm thinking of asking for a set. Thanks for sharing the photos & keep up the good work.
#72
I'm just curious why you opted for the RSR lenses rather than the 996.2 Carrera non-washer option lenses? They look the same with the fluting and appear to only differ by not having the adjustment hole through the front of the lens. Were you unaware of these as an option? Ultimately, I wish there were a Turbo (non-fluted) without washer option. But I can't seem to find any. I keep looking at Euro and ROW Turbos hoping that maybe it was an option somewhere else. But I think I'm going to have to use the 996.2 Washer delete option to get the cleaner look.
Also, here's the LED Parking lights that I am using. They look much better than the stock halogen parking lights. I thought you might like to use them in your lights as well. The color temp is nearly dead on with the Litronic low beams as opposed to the stock Halogens which are way off. They're also brighter than the Halogens.
#73
Hi, this may be a bit off topic, but I'm very interested in this project and want to know the custom DRL available.
I would like to add a DRL like below. Do you do this job?
reference:
https://store.ijdmtoy.com/products/r...ojector-35-091
reference:
#74
Up next is the HID ballasts. The stock Gen 3 Hella ballasts which came on the 996 may not look like much but are arguably the best ever made due to their strong output, very fast warm up time, and their excellent reliability. As a bonus they can be "boosted" by swapping MOSFETs to improve efficiency and adding resistors to increase the output. Think of this as turbo charging since both output and efficiency are increased, the ballasts are simply over driven so even in their uprated state the reliability is excellent. Truly phenomenal ballasts! I can boost these to 41.5, 43, 46, 59, or 55w. We decided to go right in the middle at 46w.
#75
Do you or anyone else make upgraded lights for the 996.1 I’m interested in a set
thanks Mike
thanks Mike
