Check engine code P0441
I keep getting this code. The dealer suggested replacing the fuel cap. I did and am still getting the code. It means evaporative emission purge control. They checked over everything and claim the car is proper. Anyone else experience this code? How did they rectify the problem. Thanks.
There's 4 pages of information and diagnostics in the OBD-2 manual. Has your dealer gone through that procedure yet?
From looking at this, some possible problem spots are:
a) blocked fresh air line
b) evap canister purge valve is leaking
c) hose between evap canister purge valve and air intake is leaking
d) idle air control (IAC) valve faulty
Attached my scan for the same code.
Thxs,
