LWF Release bearing question!
Is the release bearing the same as the standard Turbo part when using a LWF?
I've ordered the SACHS heavy duty bearing for the TT. Is this correct? What's the difference?
The DMF release bearing has a polyamide insert to prevent corrosion issues with the guide tube.
So don't forget the larger (by 2mm) diameter guide tube. And to lube nearly everything with Olista Longtime 3EP.
