FS: 993 OEM Litronics Kit
***SOLD***Hi again...if you are a stickler for Porsche OEM then this could be of interest...I know there are aftermarket HID kits avail and I installed Tore's on my Targa...but I wanted to keep everything OEM on my C2S so I got these which I never got around to installing...
I bot them from a 993 Turbo owner who was converting his to a race car...if I remember correctly it had about 25k miles on it..
I found out I needed other parts for the install so I sourced the rest of the bolts/rivets/brackets from Sunset...I even purchased the connector tool recommended by Geolab which I still can't figure out how to use!
one of the wiring harness clips was broken off, but they still fit snug into the ballast...can send a detailed pic for anyone interested...
I tested the power/intensity with the power leads and they are fully functioning...
also tried to get clarity of the headlight cover lens for sandblasting, etc...but it was hard to do with the camera...my C2S had a clear cover on the headlights which I didn't know about as I tried to get rid of yellowness...I noticed it had a cover so I eventually peeled it off...anyways, these litronic headlights look very clean and there is very little if at all any discoloration and were comparable if not clearer than the ones on the C2S..
asking $950 for everything+shipping...
also comes with a Pelican/Porsche instruction manual
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I just found this in the garage...it is a xenondepot HID H1 Kit that I purchased new for $260....it is essentially untouched...I was clueless as to the install....just checked their website and it is retailing now for $160....anyhow, I will throw this in for free if anyone takes the litronics....you can compare the two!
