Parts list Valve cover gasket change
Hi, I am planning to change the valve cover gaskets on both covers. I am going to do it the factory way, meaning both turbos of.
What parts do I need besides the obvoius (gaskets and bolts) if the covers and hydraulic lifters are okay?
Will return with questions around the diy when so far..
Thanks!
Thanks!
exhaust seals, large and small for both sides.
At least a handful of studs for the turbos along with new nuts.
will probably need the clamps for the cats as they like to rust
thats probably about it.
Received 5,403 Likes
Since you are going to remove the turbos, now would be a good time to install the upgraded oil line check valves from Kevin at UMW, while-you're-in-there. If you don't have them already.
Mine has 125K on it and has never smoked for more than 1 second (and thats probably condensation not oil) even if left for 8 weeks. Am I lucky? Standard oil lines on it
Depends when the the turbos were taken off last time too?
Recently did mine, last time turbos were out per my records were 2007. Basically nothing needed to be replaced.
