Radio Replacement
I am seeking advice about replacing my existing radio with a unit that has an aux. input on the back of the unit so I can hard wire for my xm antenna connection and not have it sticking out the front. Thanks in advance.
If you don't have a cd changer you can go a couple of ways. First would be to replace your head unit with a "period correct" unit. There are a limited number of options if you go this route. The OEM radios were made by Becker. Becker Autosound offers several of these radios with auxiliary inputs. Here's a link: http://www.beckerautosound.com/plug_...e%20index.html FYI: the Becker radios pictured require a minor modification to your radio wiring harness while the Blaupunkt units are plug and play.
The second option is to use a modern single-din radio with auxiliary inputs. There are a large number of options if you go this route. Take a look at Crutchfield to get a sense of what's available.
Good luck.
Jim
Good luck.
Jim
i got a becker cascade 7944 in replacement of my original radio
it fit perfectly in look
it is Ipod / iphone compatible
it got Bluetooth
it got GPS navigation system within small screen
Just perfect
it got Bluetooth
Just perfect
