Help with US Turbo S part numbers?
George, (geolab), posted a wealth of information regarding ROW Turbo S part numbers and specifications on the 993 board.
I'm trying to find correct part numbers for US spec ECU and turbos.
Is the ECU # 993.618.666.10?
If not, what is the correct P/N?
ROW P/N seems to be 993.618.689.85.
Are the US spec turbos K16s or K24s?
Please post the correct P/Ns if you know them.
US Turbo S drivers side = ????
US Turbo S passenger side = ????
Stock US turbo drivers side = 993.123.013.51
Stock US turbo passenger side = 993.123.014.51
ROW Turbo S drivers side = 993.123.013.82 ??
ROW Turbo S passenger side = 993.123.014.82 ??
Yes, I'm shockingly ignorant about these matters and I thank you for your help.
Craig
EDIT
HMMMMMM more research leads me to believe that US Turbo S was primarily an appearance package, (oil cooler too), and uses stock 993 Turbos with a chipped ECU?
True / False??
Craig
EDIT
True / False??
From what I have seen/talked, the Turbo S US spec had the regular K16 (408 bhp) turbos. But someone else should be able to tell this and confirm the P/N for the Turbo S US spec turbos.
