new race engine is ready
Tacker,
In order to use that egt set up you will need Motec or similar set up, in this case KMR which is very capable, in case of Motec you will need their E888 for the EGT's inputs,(which will work with any capable programmable ecu) so that the unit can monitor the egt's.,cheers,
You will need an expander box to put together that amount of sensors, or use an individual amplifier for each sensor and use the analog inputs on the ecu.,besides, why will you just want to monitor the numbers?, what you really want is to the computer to correct for any variances that may occur on the fly. In my case I monitor those egt's exactly like Filip has, + two more at the collectors, with these and the wide band sensors it is more then enough to keep in check the temps., which really is one of the culprits for others not achieving the right (hp) numbers.,if you need to kick ***, only the best will do (hint,hint!), cheers.
sonny1.
sonny1.
Very nice, I'm in the process of building a similar egt setup (6 for the cylinders, and 2 pre-turbo) using an E888 (feeding into a vipec v88), not sure it will be as neat as yours though.
Steve
Steve
