CEL on, code 124, Intake Air Temp Sensor
Hello Guys,
I had the Check Engine Light on the other day, I verified with the Durametric and it gave:
Code 124 Intake Air Temp Sensor
I cleared the CEL fault code and it camed back on a few days after. Checked again, same code. With the engine running (warmed up, outside air around 28 Celcius / 82F), the Durametric readout was 52 Celcius (Strange), I cleared the code again.
I checked again this morning, engine cold started, outside air 22C / 72F. No CEL for now but the readout is still 52 Celcius / 125F. So maybe my IATS (Intake Air Temp Sensor) is bad/shorted or disconnected.
Sensor seem to be P/N 99360611400, I would like to test it before I replace it. I started crawling trough the manuals but I could'nt locate it.
Questions:
- What should be the proper readout of IAT using Durametric? (close to external temp I guess, does someone have an example of the Durametric readout)
- Where is the sensor located? (Intercooler? Where?)
- Does anybody have specs of it so I can test it? (See attached image, this is what I found but I'm not sure this is the proper sensor, my guess is mine might be shorted).
Thanks in advance.
Pierre
Questions:
Thanks in advance.
Pierre
Your AIT sensor is on the intercooler, just proximal to the throttle body (passenger side). It's a standard bosch part. Mine runs within 20 degrees above ambient. It's fig B on attached pic
Curiously, the last time they worked on and had to remove the intercooler was last fall. Maybe it was not properly connected.
Anyway, THANKS for your help, greatly appreciated!
For others reference, I'm attaching photos of the IATS disconnected / connected and a proper readout with the Durametric tool (exactly as Basal Skull said, around 20C over ambiant air).
Pierre
glad it was a simple fix! with the temp sensor disconnected, the ecu puts your car in limp mode, so probably wasn't getting full boost/limiting performance
Pierre.
Resurrecting this thread...after recent 02 sensor replacement at local indy shop, ECU threw repeated P0112 codes. After removing intercooler cover, I found IATS unplugged. Thanks for the simply fix, Basal Skull!
