Gap on side skirts - normal ?
Hi guys,
Notice that my C4S (I know... its not a turbo, sigh) has a gap at the rear end of the black plastic side skirt. This is on both sides of the car. Is this normal ? Can I fix the gap ?
![](https://lh5.googleusercontent.com/-WNt_EAYsVNA/UPKqoExa3lI/AAAAAAAABCQ/XxNdrLLR29E/s640/20130113_185534.jpg)
![](https://lh6.googleusercontent.com/-rp2IQsVb8XE/UPKqnogBtCI/AAAAAAAABCM/9brYQxgdmYw/s640/20130113_185552.jpg)
Thanks guys !
Thanks guys !
It's a press on fit with little tabs that grip it. Most likely the plastics stretched/tab may be shredded. Also check that your lift/jack points aren't bent in and the plastic gets pushed in every time the car is lifted (which I think is a contributing factor). There's some nuts along the length of the car as well that can be loosened/repositioned/then tightened.
