ECU options
There's a thread on the 993 forum about someone making an easy (cheap - under 1000$) to modify plug and play ecu for the NA 993 (not sure if they are planning on making a turbo version). I don't know much about this stuff but understand the 993 t motronic is hard to modify/map (only a few people we know that can do this). But I also understand many people use ie. motec and rig up a custom wiring harness to essentially plug and play (using the stock wiring harness/sensors). Many more tuners have 'cracked' the 996 t ecu and can modify them. So how come you can't rig up a custom harness to use a 996 t ecu on our cars?
Must be a easy question for those who know. Just not compatible? Need different sensors? Completely different electronics? sorry for the ignorance.
RL Technical Advisor
We've done Motec M600 successfully (even integrating knock-sensing) on the 993TT engines, however OBD-II compliance isn't possible so that limits that option to dedicated track cars.
Totally different electronics and ECU design between Bosch M5.2 & M7.2 or M7.8. Not compatible at all.
Lucky man, you! Oregon has no such things on the horizon and in fact, exempts nothing made after 1974. Each and every '75 car and later must be tested bi-annually.
If Air Care goes away, then Motec M600 is an excellent option if you have someone well experienced with the mapping. The devil is always in the details,...
Motec is in my future (someday)
Btw Steve is THe MAN when you need any and all info on our cars.... I really appreciate you taking time to talk to me when I had my c4s...... I really thought about it long and hard and decided to sell it and I picked up a 96 993tt instead... Again thanks for all the help.........just wanted to make this public ally known......
