993tt mystery engine events - advice appreciated
- the alternator was about to die [ and it did]
- the connection into my ECU was loose [long story].
I am with Quadcammer - ECU hiccup.
Start with the obvious connections, ECU relay, ECU fuses, ECU plug. .....go internal if no joy.
Event consists of the throttle pedal "going soft", accompanied by momentary loss of power and CEL transiently illuminates. All these simultaneous, the event is over in less than a second, CEL goes off, throttle response and power come right back.
my mechanic check it and find nothing on computer, could be one of the 4 lambda sonde
will see
Hi again and thanks for new replies. After checking the simple/obvious connections I have removed the ECU and arranged for the tuner to examine and test/repair as needed. Will let you know how this maneuver turns out.
Other than the occasional "hiccup" she is a delightful beast to drive. Can be mild-mannered in traffic (well, except for the burbling exhaust), or a screamer when I put my foot in it. All good fun!
Jonathan
Jonathan
Update:
Tuner who modified the ECU discovered incomplete contact at the socket between the mother and daughter boards. Now repaired/replaced. Test drive this evening without incident. Will log some miles and see how it goes but I am hopeful.
Thanks again for all who took time to think about this issue and reply.
Jonathan
Jonathan
150mi and no blips yet, still "testing" with good results. As the tv show title says, "It's always sunny in Philadelphia".
Rennlisters are a great resource.
Jonathan
Jonathan
