Brake pad recommendations
Afternoon chaps,
My pads are coming due, and I'm wondering if there may be a better option than stock for my 99% street driving. I don't mind a bit of squeal on occasion (but prefer it be quiet) and I'd like a little more bite.
I've run hawk HPS+ on other cars and liked them, but they are not well liked here it seems.
What do you guys think?
thanks all
thanks all
I remember when I got my first 911 I read Bruce Anderson's book. He warned that one needed to be careful about "upgrades" because, in the case of Porsche, they were often inferior to original equipment. I guess I should add that this is info is over two decades old.....Chris
I don't know much about brake pads, but weren't our cars the fastest stopping cars in the World back in '96 & '97? Plus, a non stock pad would; be more noisey, beat up our rotors, and need to have some heat worked into them to reach optimum braking power (and that's not gunna happen as a daily driver).
you only need to replace pads as they wear out - there is no rule stating that you need to do both front and rear at the same time.
With a floor jack changing 4 pads is about a 25min job (of you have an impact wrench for the wheels).
I use an endurance compound on the fronts in my car, Pagid Yellows, and put Pagid Blacks in the rear, which have a bit more bite. The Yellows up front invariably wear out first regardless - usually at the rate of 2 sets of front for every set of rears. The higher friction pads in the rear serve to add a touch of rear brake bias. I have been running that setup for years and it works great.
