Clutch pack worn out (LSD)
Guest
Posts: n/a
I took my car in today to get the starter replaced. It was having intermittent firing issues, infrequent so I figured I would be proactive.
Anyway, I got her up on the lift and notice only one rear wheel is turning at a time. (Car was converted to 2WD).
Mechanic determined the clutch pack was worn out and I need a new differential. He contacted Guards Transmission to figure out a action plan.
Just curious if anyone else had this happen in recent memory and what did you do in your particular case? MarkD recommended I use GT, I understand they do exceptional work. I was unaware these have a life span of ~30k miles or so.
I destroyed the LSD that came with blackie in one season at MMC in 2WD mode. I "believe" it was a PMS unit. Don't know how many miles it had on it, but the entire car had less than 30,000 when I got it. MMC has quite a few low speed turns, which can be hard on these pieces with a relatively high HP motor when you're going to WOT coming out of all of them every lap. I could certainly light up the tires tracking out when it was going away. Replaced it with a Guard unit.
Tony, I need to do the same thing. Guard sent me the instructions and it seems like a fairly easy DIY. No engine/trans drop required.
While Guard didn't quote me a price for rebuild, my guess is <$1000.
I did the wheel spin test recently on a lift. When I turned one front wheel, all four wheels turned. That is good!
Guest
Posts: n/a
Patrick, hmmm interesting. I will contact them to see those instructions unless you can send to me.
Edit: Looking into this further, looks like they are recommending a new Torque Biasing Differential. I have a call into Mat to find out more.
Thanks!
Thanks!
Guest
Posts: n/a
I talked to Mat at Guards Transmission and he explained some scenarios bringing my differential back to spec or if I were to track this car. Also since my car is 2WD plays a factor into it, reduces cost actually since I don't need a 4 clutch diff.
He has me reading a thread showing a RL in CA replacing his on a 997, if I wanted an idea on DIY.
Not sure if that's something I want to tackle, but I find it very interesting and makes me want a lift even more.
https://rennlist.com/forums/showthre...ferrerid=97793
Anyhoo, I feel better thanks to Mat (GTgears) and another learning opportunity.
You might want to check the door panels though.
