Removal of Secondary Air Injection
Has anyone removed this system? Looks like it can be removed pretty easily (have the engine stripped down to this level), and can blank off the port on the y-pipe (pipe from the maf to the turbos).
Can anyone see any downsides (apart from slightly higher emissions for a short time after startup?
we did this on a couple of hot rod motors that we built....helps clean up the engine compartment....we even cut the boss off the y pipe....but need a program in the ecu for the check eng light...
Hello
Thanks for that, I couldn't think of any reason not to do it so will go ahead. I was thinking of making up a little plate to blank off the y-pipe boss.
Did you do anything to improve airflow within the y-pipe itself or did you decide there wasn't much to gain?
Steve
Steve
i removed the changeover valve & solenoid along with the plumbing and the secondary air pump. no downside. for me, it's a weight savings and elimination of a potential headache.
