H&R bump stops
Quick question guys, currently fitting H&R coilovers and I have a question about the rears. The supplied bump stop is about 10mm taller than the Porsche original one....no problem I thought untill you try and fit the original dust cover to the new bumpstop and realise it doesnt secure to the stop at all (bigger diameter and falls over the stop_ No problem I thought I will just use the original bumpstop and gaiter but then noticed that its shorter and therefore wont offer the same level of protection. So my question is for guys that have done this and what they fitted. One suggestion has been to order and fit the items fitted to a turbo S as they are apparently designed for Bilsteins which I assume my H&R's are.....thanks guys
Mark
P.s there wasnt/isnt a gaiter supplied with the kit.
Mark
