LED conversion of instrument cluster
Anyone know where to get the twist lock bases to accommodate the #74hp3 wedge LEDs from superbrightleds.com? A prior thread mentioned that the bases from Porscheleds.com could be used, but these come with a non-removable led bulb. Seems that the twist lock needs a double contact.
I believe a number of listers have tried it [including me]. some worked ok, most didn't. i found, while the chinese made leds look similar, they were a few thou out here and there and didn't fit correctly.
search on the non-turbo 993 forum, plenty of info there.
good luck
good luck
74hp3, 986, 993, 996, cluster, conversion, instrument, instruments, led, leds, panel, pictures, porsche, porscheledscom
