Buzzing noise from climate control unit
There is a loud buzzing noise which appears to be coming from the vicinity of the climate control unit, and remains for a while when the key is in the off position. Any ideas? Thx
I am having trouble getting the CCU out. Do you need to insert the "coat hangers" in order to push from behind? I tried that and it didn't budge. Any other tips to dislodge the CCU?
You can buy the removal keys from any general auto store...in the UK I would say halfords but in the US, i'm not sure. Alternatively you could do what I did and make a couple of keys out of a wire coat hanger....the images on the web should show you what you are aiming for as a design. It also helps to reach under the dash and push the unit forwards out ou the dash while the keys are inserted.
cheers
cheers
