Clicking when in gear on throttle
For the past few months I have been bothered by a rapid clicking when the car is in gear and on throttle. It is most noticeable in the higher gears, but probably because the engine noise is less. The sound comes from the right rear. There is no noise if I am moving, but not on the throttle. There is no noise if I rev the engine in neutral. Earlier in the year, I thought this was from my transmission, but second gear broke in June and transmission was rebuilt. The noise is still there.
Rennlisters...any ideas?
I'm Still Jenny
I know you say the clicking sounds like it's coming from the right rear, but I had a similar noise and it turned out to be that the shift **** had worked its way loose and was rattling.
