Cost of lower valve cover gasket replacement
I have an oil leak originating from lower valve cover gasket - does anyone have a sense of cost for replacing these (would do both sides). Am awaiting a quote locally (BC).
Apparently these dry out and crack due to high temp in this area of engine - is anyone aware of any meaningful aftermarket options to discourage it happening again?
Thanks for any input.
Search the words, "lower valve cover gasket" in the 993 Turbo Forum, and you will get a ton of great info. Here are a few to get you reading through the weekend:
https://rennlist.com/forums/993-turb...e+cover+gasket
If you are mechanically inclined this is something you can do yourself for the cost of parts. If you go this route be sure to read up on the DIY procedure as there are a couple of gotchas to be aware of. Ask me how I know
Edit: I did this on my 993. With the TT you have to remove the turbos so that adds some complexity (and labor if the stealer does it).
