Check Those Tire Pressures
09-09-2010, 07:58 AM
Wow, big air temp changes going on in the Chicago area. Check those tire pressures. I was down about 2-3 PSI from the mid-summer settings.
09-09-2010, 08:43 PM
what # do u keep the tire pressure at in this Midwest weather?
09-09-2010, 10:00 PM
the rule of thumb I heard was for every 10 degree temp change, there is a 1psi change.
09-10-2010, 10:56 AM
Quote:
Originally Posted by
racer
Correct, for "dry" air.
09-10-2010, 10:57 AM
Parnelli
I am 36/40 in the Turbo (Kumhos on 18") and 32/36 in the Boxster (PS2's on 19").
Reason: added tire and wheel info
09-10-2010, 11:09 AM
Boost JunkieLifetime Rennlist Member
09-10-2010, 12:35 PM
AddictRennlist Member
09-10-2010, 03:50 PM
racer
beware PV = nrT !!!!!!!!
09-11-2010, 07:26 PM
I like 35/40 with Sport Contact N2's which is around what most guys on this thread run. I asked the Michelin guys at the Mosport Porscheplattz and they went on and on about how Porsche did extensive testing and we should be sticking to the pressures recommended in the manual......36/44 if I recall. My indy recommends the lower ear pressures too. What do you think?
09-12-2010, 12:26 AM
in sf with potholes...
38f
44r
have already bent a couple rims...
ran low 30's one time...tires lasted about 4k miles...no thanks
