Lowering Springs vs. Coil Overs - 993 TT
The objective would be to lower a stock twin, to European ride height or maybe a drop lower. There would be no track days, just spirited road driving. Would a set of quality springs from H&R suffice or are coil overs the way to go? What are the down sides of each?
Seems like lowering springs would be acheiving the objective with the least alteration from "original."
Thank you
Thank you
Boost Junkie
the real problem is the stock shocks are likely toast or soon will be. Even if you want to stay close to stock in ride quality etc, go the OEM M030 springs and and Bilsteins HD shocks route
I hear great things about K&W, but not sure about quality compared to H&R's. The K&W's may also be a bit more track oriented.
Which do you guys feel would be best for the road, no track? Are there any others that should be considered?
H&R's aren't in the same universe as the KW varient 3s. With that said that would too much for a non track car even though the KW's are adjustable.
Best set up would be RoW M030 for what your asking.
