Ignition Coil
Crane have just mailed me to update their recommendation for the coil to the LX91 730-0891 as apparently this will suit our cars better.
I'm going to order and see what happens (doesn't look too hard to fit)
Steve
Steve
I know is an old post, anyone tried Crane LX91 730-0891 coil?
That's what I presently use with Denso IK22's gapped at .020-.021. Solved my hesitation at about 5000 rpm. Extra boost was extinguishing spark prior to complete combustion. Hope this helps.
thanks
+1, I run the same thanks to Overboosted as well. he recommended them and work like a charm.
^^^^^^^^^. Did you have the CDI before you went with the PK's?
I was having missing/hesitation when my gap was anything larger than .024. If you installed the CDI after, I'd say that was the greatest contributor to ending the misfires.
