tt Muffler bypass- removable baffles available?
Got the FVD bypasses for $243.20- they look great, my son loves the sound but are they loud! The butt dyno notices better response and we believe the rear cooling and weight benefits as well. Have looked online with limited success to see if any pipe baffles/ silencers exist to easily install/ remove. Am in upscale 'hood and don't want to upset any neighbors. Anyone have ideas to quieten things down a bit? Saw this innovative post but am looking for an easier to install/ remove solution for track days...
https://rennlist.com/forums/993-turb...***-drone.html
Thanks!
Thanks!
You could still use the CC inserts but mount them the same way Fabspeed mounted the fiberglass baffles in their earlier generation SuperCups. That version of the Supercup had screw holes drilled on the sides...once the baffles were slipped in (friction fit), the screws were install to retain the baffles and prevent them from getting blown out the pipe. Another alternative is to have some turn-down pipe fabbed up and attach them to the ends of your muffler tips.
