For the first time, BANG
Well today for the first time I came off a light, and saw a very rich looking puff of smoke come from the rear. I went through the gears like normal and it seemed fine. At the next light I gave it a blast in second gear and heard a loud backfire around 5,000 rpm. I then checked the last boost on the profect B and it was still just 17psi. I put it in third and rolled into it a bunch more times and it was fine.... no check engine light, can it be bad post cat 02's? It seems to run fine now..Thanks for input
I'm Still Jenny
I believe that only the primary (pre-cat) O2 sensors determine mixture/have any role in engine management and the secondary (post-cat) O2 sensors are only used to determine whether the catalytic converters are working or not (so post-cat O2s can throw a CEL but won't have any bearing on the car's operation).
Fresh Turbos, Valve covers and gaskets. She's bone dry... Looks to have been rich for a second. I'm going to take out the mass air and give it a clean first.
Well cleaned the mass air today and it did have some black color on the elements. I have a Pro- Flow larger mass air in the car, and it comes apart to clean. All hoses were tight. Took it for a ride and it runs fine... I don't know, just a small brain fart I quess. Thanks for all of the input.
