Budgetary Numbers?
I'm trying to plan out my winter projects to upgrade my 993TT to something like a Stage 1 UMW kit. I will do all of the work myself, so this is really just a parts build price sheet.
Kevin doesn't have prices on his website, and I don't want to bug him considering I'm a few months away from doing this.
I see the parts list as:
1) Pair of upgraded Turbos
2) ECU Upgrade
3) New Cats
4) Gaskets, bolts, nuts etc.
I'm a street-only kind of guy, so I'm not trying to build a track monster. I have a newish clutch, so not going to go that route (yet). I just did a 60k service (early, at 34k) in February, so won't need most of that. I'm trying to get a very streetable ~450ish hp with a very linear powerband.
How much should that setup run me (rough order of magnitude is fine)? Is it really stupid not to upgrade oil coolers and intercoolers even for street use?
I'm sure I'll have other questions, too!
2) ECU Upgrade
3) New Cats
Hi this is a couple of years old but you'll find what you're looking for in this thread. https://rennlist.com/forums/showthre...ferrerid=28499
I don't think you need a up graded intercooler for this kit/street use (what is an upgraded intercooler as you may know is another topic). I'd do an upgraded oil cooler - turbo S/cargraphic/ruf/home made - although you probably don't need it...
While Basal Skull may be right, I'd opt for the safety of upgraded oil coolers. Compared to what you are spending on the other stuff it seems like cheap insurance to me. The cooler the engine the safer. I opted for dual cooler with the Jay Putnam kit and they keep my car cool under heavy boost and scorching florida heat.
I think this winter I'll do the upgraded oil coolers, replace the spark plug wires, replace the intercooler plumbing, and maybe switch over to 100 cell cats.
I believe the FVD twin coolers, Jay Putnam cooler and flying fin/my version (https://rennlist.com/forums/showthre...ferrerid=28499) are pretty similar. Mine work pretty well on the track and the fans are pretty nifty when you're stuck in traffic or when you're doing your 2 min+ idle cool down in the paddock for the turbos when you come off the track!
While you're in there ... (famous last words)... look into the grinding of the exhaust header to smooth the flow. This is another of Kevin's speed tricks and while I wasn't able to actually test it on Waldo, it make perfect sense to do it. Kevin can send the details on how to do it. A big part is cleanup... you do not want any metal bits in your new turbos!
Basal Skull, I checked out your link and that is super cool. I think I'll do that as well. Is there such a thing as "too cool" in terms of oil temperatures? Since I don't plan to track the car, maybe going to the same levels you did would be overkill on a modified motor?
If anyone wants to do a group buy, I'll organize it.
I wondered about this as well but the consensus seems to be the cooler the better. Since the plumbing is going into the front fender mounted oil cooler circuit in series, and the circuit/thermostat only opens at higher temps, figured it should be okay.
