993 GT2 rocker extensions
I was wondering if anyone has a set of GT2 rocker extensions for sale? My car does not have them and I prefer the look with them rather than without. They can be used or off a race car or whatever, as I will be reworking them. Any installation know how would be welcomed also...I will include a picture of my car....Thanks Steve
Steve, welcome and nice car!
The GT2 did not have rocker "extensions". From the pic I take it your GT2 conversion is based on a narrow body 993. The GT2 is based on a WB 993 and thus uses the regular WB rocker panels. Usually the GT2 kit flares available for NB 993s also include the rocker panel extensions. You might want to check with FVD for example. The rear flares I have seen for NB 993s extend all the way down to the rocker panel extensions. Yours seem to be the WB type, which ends further up on the rear fender.
GL either way.
GL either way.
There are no GT2 rockers, only wide body ones. You need the lower rockers off a wide body car as you have a narrow body car. These are metal and I can't imagine the work involved to get them off a donor car and onto yours. I would first look at what getty has
http://www.gettydesign.com/PDF%20Fil...%20Catalog.pdf
Check out page 29. Would be easier/cheaper going this route but it will be some decent work to get them to blend into the body like the oem widebody ones
good luck!
good luck!
