Turbo lag - delay in boost
Hi
My father has experienced turbo lag with his 993 turbo from 2800 rpm.
The turbo is behaving as a normally aspirated car at the moment.
Our Porsche Centre have checked the turbo's and they are 100%. The regulator is fine, and there is no air leakage from the pipes, waste gate etc. The car is behaving like a 930 Turbo with all the boost coming in at 4000 rpm, although it seems to surge.
Our Porsche Centre say that they think it is the timing chain etc.
However they cannot guarantee that to be the problem. An independent service agent is convinced that the fuel injector jets need cleaning, as this has never
been done.
Any advice?
Thanks so much
been done.
Any advice?
Thanks so much
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Hi
been done.
Any advice?
Thanks so much![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
been done.
Any advice?
Thanks so much
I usually run my gas tank to less than a quarter tank, add the bottle of Techron, then drive around for a little while. Open it up a couple times on the highway, and it should help.
After that, fill up with best quality gas you can find, and see what your results are. Try this link for Top Tier gas providers:
http://www.toptiergas.com
For less than 10 bux, I'd try to run a bottle of Chevron's Techron through it. You can pick it up at your local parts place.
thanks!!
