Rattling noise when turning steering wheel
Recently my 1997 993 Turbo has developed a rattling noise whenever I turn the steering wheel clockwise. The noise occurs at the final 1/2 turn of the steering wheel, before it reaches the full stop. It seems to be stronger when the brakes are applied as I turn the steering wheel. When sitting in the driver's seat, the noise appears to come from somewhere close to the left front wheel well.
My first suspicions go towards the steering rack. However, my technical knowledge of these beasts are pretty limited.
1. How can I check what exactly is at fault? Put the car on jack stands and have an assistant turn the steering wheel while I listen up close?
2. If it is not the steering rack, what else could cause this noise?
Thanks for the feedback.
Rik Gruwez
Bruges, Belgium
Rik Gruwez
Bruges, Belgium
Do you hear it only when rolling?
is it a sort of clicking noise?
Sounds like the outer CV joint on one or both front axles.
MarkD is suggesting that if it is there when rolling but not when standing, it could be the CV joints. Now, as you stated that it is there when stationary, it won't be the CV joints.
I'd vote for upper strut mounts or lower control arms. I had a clunk that I could feel in the steering, so I replaced the lower control arms to no effect. When I replaced the upper rubber mounts it went away. The upper mounts are much cheaper, so do those first. I couldn't tell by looking that they were bad, but could hear the clunk with my head in the wheel well.
OK, so you can make the noise happen standing still. As Malcolm said, that rules out CV joints.
Could be rack, could be supsension as Q45 suggested...
IMHO, it will be hard to diagnose here. Maybe get someone to turn the wheel for you while you track down the source of the noise? Good luck and let us know what you find!
Regards,
Rik
I did, but then the car sits so low I cannot really crawl underneath. But the noise is still there. Ideally I would need to drive it up a ramp hoist. Perhaps best to drop it off at the dealership...
I think we are heading for what Q45 suggested, suspension related.
Though it is still possbile the rack only makes noise under load.
You said it is only the farthest ends of steering travel so probably suspension when under a load.
Do you get any vibrations in the steering at any speeds?
If yes, control arm bushings are the likely culprit. Chris Walrod (here on RL) has a great replacement uerthane bushing.
Otherwise, could be ball joint or tie rod. Given the noise you are hearing at the end of steering travel, I'd suspect ball joint... though I can't say I've ever heard that noise caused by a ball joint on one of these cars.
Are the strut tower nuts tight (top side)?
Are the lower strut bolts tight?
Does it start vibrating at about 45-50mph and go away around 60mph? (sorry, didn't covnert to KPH)
Thanks a lot for leading me in the right direction. Now I only need to find out if I can do it myself.
Regards,
Rik
If you change the control arm as a unit, it's easy to do yourself. The factory bushings are kind of complex and I wouldn't recommend swapping for urethane.
