993 Turbo Forum 1995-1998
Bad Knock Sensor
Old 09-29-2008 | 11:22 AM
Spartan's Avatar
Spartan
Default Bad Knock Sensor
Code 211 - Looks like replacing it is easy enough. Does anyone know what the torque setting is though? I don't have any factory manuals
Car seems to be running great although I did read that the ecu will pull 6 deg of timing if it senses a one is on its way out.
Part# 993-606-141-00-M14
Old 09-29-2008 | 12:29 PM
911/Q45's Avatar
911/Q45
15 ft lbs.
Old 09-29-2008 | 12:52 PM
Spartan's Avatar
Spartan
Thank you sir!
Old 10-03-2008 | 06:05 PM
Spartan's Avatar
Spartan
Has anyone here done this by any chance? Installation seems easy enough esp since I don't have an air box or AC to get in the way.
Any advice would be appreciated Kicking myself for not jumping on that reasonably priced shop manual
Old 10-03-2008 | 07:28 PM
911/Q45's Avatar
911/Q45
Mine were replaced off the car, seems like running the wires is the tough part with the engine installed.
Old 10-03-2008 | 07:43 PM
Spartan's Avatar
Spartan
Looks like they are both located on the top by the center injector on each bank. The wire from the sensor to the connector doesn't seem to be all that long. I will take a few pics and add it to this thread for future reference.
Old 10-03-2008 | 09:24 PM
MarkD's Avatar
MarkD
here are a few pics, hope this helps.
first one is pass side sensor from rear through alternator/fan opening
Second is from the outside, see red circles.
Third is the driver's side through alt/fan opening
once fan housing/alternator are out it shouldn't be too bad
Quick Reply: Bad Knock Sensor
