Clutch pedal fluid, Brake or Power Steering?
Newbie question / confusion.![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
The owners manual mentions that the brake fluid reservoir is also used as for the hydraulic clutch. On the interweb I am also finding references to the power steering fluid as also being used for the hydraulic clutch on 993 turbo models.
I also understand (I think) in addition to the primary transmission / engine clutch on a 993 TT, there are "clutches" use by the AWD system.
So on a 96 993 TT which fluid is used to assist the clutch pedal?
Cheers,
Kevin
Cheers,
Kevin
Hi
on the 993tt, the brake fluid is separate from hydraulic clutch/steering fluids. (different from 993).
don't think there are any 'clutches' on the AWD system - just a viscous coupler.
Pentosin is used for the clutch - there is a main reservoir in the engine bay and a smaller one in the front trunk.
Turn to:
Capacities, page 152, "Porsche 911 Carrera 911 turbo Owner's Manual"
Power steering
Carrera; Carrera 4, Carrera 4S: approx 1.05 U.S. qts./1.0 liters hydraulic fluid ATF-Dexron ll D
Power steering, clutch
Turbo: approx. 1.8 U.S. qts./1.7 liters hyraulic Pentosin CHF 11 S
Brake fluid rservoir
Carrera: approx. 1.05 U.S. qts./1.0 liters
Carrera 4, Carrera 4S, Turbo: approx. 1.48 U.S. qts./1.4 liters
Only use original Porsche brake fluid
Power steering
canysmc, thanks for the extra details from the manual, I didn't catch the "Carrera" caveat when looking in the manual
and didn't think to look in the "Capacity" section of the manual, d'oh.
I did Google "Pentosin" which led me to the conflict / confusion with the brake fluid thinking.
I am now of the thinking, "slave cylinder" given "Mark in AK"'s great diagnostic photos in another thread
I think in my truck I may have two issues. Maybe during the 30K brake fluid replacement, it was overfilled and not cleaned up completely, which caused me to leap in that direction (along with NA 993 threads on clutch hang / stick issues), but now the most likely suspect is the slave cylinder.
Cheers,
Kevin
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
Cheers,
Kevin
