How to tell if I need diverter valves replaced?
Is it a catastrophic failure or a gradual process?
Is it a sluggish acceleration issue, or is it more in terms of difficulty to get boost above a certain bar?
With diverter valve threads searched, I think I want to replace these with billet ones (http://www.amazon.com/Forge-Motorspo...963739&sr=8-10).
but just want to know if it is a must right away or something I can wait until next few months or next year, and how I can tell if mine are shot. Thank you!
Usually they make a honking sound when going bad. If they are stock and you suspect that they are going bad then the probably are, these things should be replaced every so often. Just replace with Stock or you can spend the $$$ for the shiney metal ones which give you mad pOwar
Better yet replace with the Bosch 710N vs the stocker
Had the same "honking" sound and after replacing both diverter valves it`s gone.Did replace them with original and are happy with them but do you have the Bosch number on the 710N valve ?
Spartan : Tell me more about the hybrid turbos that you have for sale.
Thanks.
/ Kurt
Thanks.
/ Kurt
I don't have enough open roads and cop-free zones to test the boost to see how freely it boosts up. I understand most cars with diverter valve problems end up not boosting much above 0.7....
No....just worrying about bits of plastic from stock valves breaking off and the such. I don't hear any whining.
Don't worry about the plastic valves. I've run them in cars boosting 25psi+ for years and had zero issues. The only issues i had were with the forge metal ones which turned me off on those types of DV's.
What kind of problems did you have with the Forge metal DVs? Those seem to be popular....but I like to know your experience with them.
what is generally called honking on this forum....could it be a higher-pitched whistling sound? Or is it a lower HONK kind of sound? I do hear a higher pitched whistle coming more prominently at @ 3000 RPM.
