Dimensions 993TT vs. 996TT ??
On first glance the 993TT appears to be a fair bit smaller. Is this really the case? Does anyone have lenght, width, height and weight comparisons for the 2 cars?
ps. Posted this in the 996TT forum as well so my apologies if you've seen this twice.
go to a dealer or repair shop. you will find na 993 and 996 to compare same size as tts. should be easy to find.
btw the 996 needs to be wider to accomadate all that water stuff!
993 Turbo
Curb weight: 3,307 lbs
Wheelbase: 89.4"
Length: 167.8"
Width: 70.7"
Height: 51.8"
996 Turbo
Curb weight: 3,480 lbs
Wheelbase: 92.5"
Length: 174.6 in
Width: 72 in
Height: 51 in
997TT converted to inches from info below
Weight: 3520lbs
Lenght: 175.19
Width: 72.9
Wheelbase: 89.4"
Length: 167.8"
Width: 70.7"
Height: 51.8"
996 Turbo
Wheelbase: 92.5"
Length: 174.6 in
Width: 72 in
Height: 51 in
Weight: 3520lbs
Lenght: 175.19
Width: 72.9
993 = le femme 36-26-38
996 = le femme 37-37-39
Almost the same maximum width, but, you get the picture ??
Rennlist Lifetime Member
