Immobilizer M 530
Hi chicos!!!
I have a problem with my 993TT.
The inmobilizer M 530 has spoiled and wanted to know if some of you has been able to disconnect this piece for always because it is a problem that already has happened in my car in three years.
Is there some way to annul this system?
Thanks and best regards!!!!!
Davidito![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Davidito
Rennlist Lifetime Member
I believe you would need to have your ECU re-coded so that it's not waiting for the dis-arm signal from the drive block unit before allowing the car to start. And you might need to make other changes as well. In short, the answer is that's it's not easy.
It`s very complicated but we can try it.
Gracias Jean, mensaje privado contestado.
Cuando vengas a Madrid la próxima vez tienes unas cervezas y un amigo para lo que haga falta!!!!
Muchas gracias de verdad.
www.pasionporsche.com
