Will 996 Rturbo Wheels Fit 993TT?
Why do I feel so left out!
Yes,
Not sure about the spacer - it maight have to be a bit smaller with the 305's?
Best of Luck,
SImon.
Best of Luck,
SImon.
depends on the offsets, I have an et of 34 on mine with 11" rims, i could not fit 305's under the arches with that offset, you may be able to with an offset around 40-45 but I dont know if they will clear the rotors/breaks
Rennlist Lifetime Member
Given that they're 19s I would have though there won't be rotor/brake clearance issues virtually regardless of the offset. It's bodywork and suspension clearance that are potential issues, no?
I have that same wheel, same spacer, and same sized tires (but different brand) on my 993TT. No rubbing issues, no rolled fenders, no crazy camber angles. Go for it.
What tires are you running? How are they size up with MPS2?
For some reason tireracks listiing the 305 as more expensive than the 315.
305/30ZR19
Blackwall
* N1 (Porsche)
* Serv. Desc: (102Y)
* Load Rating XL
* Price: $520.00 (each)
* Estimated Availability:
In Stock
Warranty Rating 3.5
Qty:
315/25ZR19
Blackwall
* Serv. Desc: 98Y
* Price: $508.00 (each)
In Stock
305/30ZR19
Blackwall
* N1 (Porsche)
* Load Rating XL
In Stock
Warranty Rating 3.5
Qty:
315/25ZR19
Blackwall
* Serv. Desc: 98Y
In Stock
Vincent,
I have Continentals... prolly not the best choice. I think the actual tires should be very close in size, but I don't know.
Barney,
Yes, Ruf wheels. My car is a total Ruf Turbo R conversion with every bell and whistle (except the instruments).
Barney,
Just purchased these 19" Ruf wheels. Simply gorgeous.
Front 8.5x19 w/ 235/35/19 MPS2 weighs 51lbs.
Rear 11x 19 w/ 315/25/19 MPS2 weighs 61 lbs.
Rear 28mm Spacers and lugs x 2 weighs 16lbs
Total 240 lbs Ouch!!
