Wanted: exhaust bits
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I am looking for exhaust mounting hardware to purchase.
Cat to muffler clamps, doughnuts
Cat mounting straps
heater ducting hoses (two oval orange shaped connections that connect the heat exchangers to the cast ally heater ducting above the cats)
Anyone have such items for sale?
Cat mounting straps
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Hi Doug
Well, a number of things really. And still getting there, you know.
As for the overboosting and subsequent fuel cut, resetting the boost controller (Greddy) settings back to mfg recommended start settings, then slowly creeping the settings back up a little at a time, the car responds nicely. Currently seeing .85 max is enough for me until I learn more about this car. I am still not certain about the aftermarket boost controller.
I am amazed at how quickly boost builds. Hard to describe.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Seared
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Still collecting exhaust bits -- just to get it smogged then I will look into a great sounding system, aftermarket or modified standard bits.
Curious if anyone has the clamps and doughnuts that couple the cat to the mufflers, then mufflers to the tips. Anyone have such bits and pieces laying around? Dealer is backordered for months on the clamps and doughnuts
Chris
I have a couple of clamps that couple the tips to the mufflers.Are they the same?If so you can have them.I may have donuts as well,I will have to look.I am cleaning the garage up a bit today and might be able to locate them.I will snap a picture for you.I will also look under my Turbo and see if they are the same
