Turbo Tranny in a Na 993?
Do you guys know if a TT reansmission will fit in a 993 C2? I know the tt is awd but I mean is the housing the same? I heard that it is longer (the bellhousing). Thanks, Mark
The TT gearbox is longer and heavier -- courtesy of the bigger ring & pinion so the bell housing is bigger. Generally speaking-- a 993 N/A gearbox with ratios is a better option. Definately adaquetly strong enough for any N/A engine. The TT gearbox will fit FWIW.
