Wheels (offsets etc)
Hi,
I have been offered some wheels for my 993 but I am a little confused about offsets etc
the rims i am looking at are 11x18 rear with offset 34 (think the std is 40 on a 10x18 wheel) and the front are et40 and rim size 8.5x18 (the std is 8x18 and et 52 i think)
do you guys think these will fit ok on a 993 turbo or will i need to modify the arches etc (i do not want to do that)
thanks
John
thanks
John
Find an offset calculator online and run the stock vs new wheels to tell where they will end up.
http://www.1010tires.com/WheelOffsetCalculator.asp
thanks, do you know if i have got the correct offsets/sizes for normal, and what kind of play have I in space, can it be 10mm over on the inside and 20mm extending from normal, i do not know how tight the wheels are at present.
thanks
thanks
...the rims i am looking at are 11x18 rear with offset 34 (think the std is 40 on a 10x18 wheel) and the front are et40 and rim size 8.5x18 (the std is 8x18 and et 52 i think)...do you guys think these will fit ok on a 993 turbo or will i need to modify the arches etc (i do not want to do that)....
btw what wheels are these?
