993 Turbo Forum 1995-1998
Reasonably prices cat deletes?
Old 11-09-2007, 09:00 AM
eclou
eclou's Avatar
Received 1,222 Likes on 598 Posts
Default Reasonably prices cat deletes?
Has anyone seen these?
http://www.haywardandscott.com/Detai...33&category=16
Old 11-09-2007, 09:27 AM
Barney1
Barney1's Avatar
Less than what I paid.
Old 11-09-2007, 09:34 AM
DM993tt
DM993tt's Avatar
I bought these - no cat no muffler hook these right up the turbos!!
http://www.awe-tuning.com/pages/shar...&IL=993tttestp
Old 11-09-2007, 10:47 AM
Barney1
Barney1's Avatar
No CEL light with those? Where is the 2nd o2 sensor.?
Old 11-09-2007, 11:42 AM
IamSMC
IamSMC's Avatar
I also have the AWE muffler and cat bypasses
They have provisions for the pre cat O2 sensors
The post O2 sensors are left "hanging" to fresh air, you do this to complete the pre cat to post cat readings, you do not remove them
The ECU will adjust accordingly
To date, no CEL light
BTW, I also have my engine tray cover removed to aid in engine cooling and to prevent excessive heat buildup/readings
Old 11-09-2007, 11:45 AM
Barney1
Barney1's Avatar
Wow.. Great.
Old 11-09-2007, 12:00 PM
IamSMC
IamSMC's Avatar
Originally Posted by Barney1
Wow.. Great.
But the only hard part now is getting your hands on a set of AWEs
AWE seems to be concentrating more on the 996/997 then the 993
Old 11-09-2007, 12:21 PM
dbf73
Boost Junkie
dbf73's Avatar
bet your neighbors love those things
Old 11-09-2007, 01:20 PM
jhargis
jhargis's Avatar
Do the muffler bypass pipes hook on to the end of the cat bypass pipes?
Old 11-09-2007, 01:27 PM
IamSMC
IamSMC's Avatar
Hee hee hee......
Old 11-09-2007, 01:34 PM
IamSMC
IamSMC's Avatar
If you're asking about the AWEs bypasses, you remove the mufflers and cats. The AWEs bypasses bolt directly to the turbos.
With Fabspeed and similar, you retain the cats and bolt the muffler bypasses to the cats.
The AWE muff/cat bypass design are different from the Fabspeed muff (only) bypass design.
AWEs design is supposedly designed after the same design by Porsche Motorsports.
And the Porsche Motorsports ones are supposedly $3k+.
Old 11-09-2007, 01:54 PM
jhargis
jhargis's Avatar
So there are no muffler tips that stick out from under the back of the car, like the normal look with mufflers on the car?
Old 11-09-2007, 02:18 PM
DM993tt
DM993tt's Avatar
When you bolt the AWE pipes on the design is so they fit and exit right where the stock cutouts are. The look is exactly like the Porsche Motorsport GT2 EVO Pipes - just costs less but the fabrication is excellent (they even ingraved my name next to the serial #) The AWE pipes are loud and perform better with K24's or hybrids. I have K16's and they are great on the track!!!!! (A bit too obnoxiuos for street use)
Old 11-11-2007, 11:57 PM
jhargis
jhargis's Avatar
So you notice a big improvement in performance when you put these on?
Old 11-13-2007, 12:46 PM
AndyT
AndyT's Avatar
Default EVO Pipes
I have the Evo pipes and the improvement is huge. They may be for sale since the car is.
Quick Reply: Reasonably prices cat deletes?
