Heat from engine
Heat from engine
Hello to everyone,
I am experiencing alot of heat in the driver's cabin radiating from the engine. Was wondering if this is normal or are there any remedy's for this.
Thanks!
Thanks!
the heat is not coming from the vents.....its actually coming from the engine.....the rear part of the cabin gets warm....i was thinking that the heat shielding needs replacement
I had mine replaced not too long ago, it makes some "perceived" difference.
There is a multitude of products out there for heatshielding the engine bay and some of the engine components, inexpensive, effective and easy to use. It should not be the norm though, unless you have some special setup or padding removed.
