993 Turbo Forum 1995-1998
Window Switch?
Old Sep 18, 2007 | 09:19 PM
sealbeach1's Avatar
sealbeach1
Default Window Switch?
Hello everybody,
I have a quick regarding the replacement of the driver door window switch,
do you have to remove the door panel of can the switch be replaced without removing the panel?
I would appreciate any help.
Thanks,
David
Old Sep 18, 2007 | 10:04 PM
IamSMC's Avatar
IamSMC
Window switch should pull straight out w/o door panel removal.
Old Sep 19, 2007 | 01:44 AM
Turbodan's Avatar
Turbodan
it does pull right out, pry it from the sides with a screwdriver wrapped in a cloth. then unplug switch
for passenger side, both switches must be operational for the window to go down. common problem. I think the switch is $35 cdn
there is a diy fix with toothpicks but I think it is only temporary and time consuming.
Old Sep 19, 2007 | 11:12 AM
IamSMC's Avatar
IamSMC
maybe a plastic spackle knife is a good option also for prying
Old Sep 19, 2007 | 12:02 PM
sealbeach1's Avatar
sealbeach1
Thank You Guys,
I knew I get the right answers here.
David
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
