993 Turbo Forum 1995-1998
The project is moving on..
Old 09-13-2007 | 11:53 PM
Barney1's Avatar
Barney1
Default The project is moving on..
Well here it is so far. Im at a dead end waiting for a right side Turbo shield. I could have had Barney running tonight. I'll just sit back and CHILL.....
Old 09-14-2007 | 01:38 PM
WHB Porsche's Avatar
WHB Porsche
I'm Still Jenny
Looking good. Are those the Andial oil lines on the turbos?
Old 09-14-2007 | 04:03 PM
Barney1's Avatar
Barney1
The lower rear lines are and the top feed lines are Tony Callis racing...
Old 09-14-2007 | 08:16 PM
WHB Porsche
I'm Still Jenny
Thanks. What did you have to remove to get to the lower valve covers? I imagine wheels, rear bumper, turbos and plumbing, inner wheelwell?
Old 09-16-2007 | 10:12 PM
Barney1's Avatar
Barney1
Yes all of the above....and then some. Not bad, it took me 3 hours to get down to the valve covers. Now I'm stuck waiting for a right side turbo heat shiels thats on backorder.
Old 09-16-2007 | 11:45 PM
IamSMC's Avatar
IamSMC
How much they run you?
Contact info?
Old 09-17-2007 | 10:22 AM
Barney1's Avatar
Barney1
The hard pipe is Andiel, those were on the car. I baught the feed lines and check valves from Tony Callis Racing. Kevin from UMW has the line kit cheeper.
Do a search on Ultimate Motorworks.
Old 09-17-2007 | 01:57 PM
vrus's Avatar
vrus
Hard pipes?? Hmm. I didnt realize Andial made a hard pipe kit... Gotta run.. Gotta make a phonecall...
Old 09-17-2007 | 05:05 PM
911/Q45's Avatar
911/Q45
I think he means the hard oil line, as opposed to braided.
Old 09-17-2007 | 07:13 PM
Barney1's Avatar
Barney1
Well, the return lines in the rear of the turbo oil tank are the hard lines.Those are the Andiel.
The braided lines in the photo are the feed lines with the check valves from Tony Callis Racing.
Quick Reply: The project is moving on..
